Group: DynoMotion Message: 547 From: Marty Escarcega Date: 8/9/2010
Subject: Single point threading on the lathe
How close are you to implementing single point threading on the lathe? Either with your software or ultimately the Mach III plug in.
Thank you!.
Marty
Group: DynoMotion Message: 548 From: Tom Kerekes Date: 8/9/2010
Subject: Re: Single point threading on the lathe
Hi Marty,
We are cutting good multipass threads via a KFlop User C Program.  See the email and video from a User below.
So currently it is possible to do threading performed by KFlop triggered by an M command in either Mach3 or KMotionCNC.  But we are just beginning to properly integrate it with Mach3 or KMotionCNC.
Here is a plot of captured data showing how the Lathe Carriage accelerates and synchronizes with the desired spindle position.  This data was captured with a spindle speed of ~360rpm and cutting a 5mm pitch thread.  The plot's horizontal axis is time (seconds), the vertical axis is z encoder counts (400cnts/mm), green is the z axis, purple is the desired z position based on spindle position.
It would be nice if others could test.
Yesterday's exercise was very pleasing.
The results are excellent and I have posted a short video a thread that I cut after our initial tests.
I altered the figures, as you suggested, and the result is a 1.5mm pitch thread on the nylon rod.
I also did a 1.75mm pitch.
Both are excellent - lead-in is spot on.
The threading video is the last one.
http://www.kumeu.co.nz/hankooklathe/
I will get to posting on the forum :)
Group: DynoMotion Message: 549 From: Marty Escarcega Date: 8/9/2010
Thanks Tom. That helps. How would one test? Do you have a beta version of the software enabled for threading G codes?
To use your hardware does one have to be versed in programming in C? (I am not)
Marty
Sent: Monday, August 09, 2010 12:38 PM
Subject: Re: [DynoMotion] Single point threading on the lathe
Hi Marty,
Sent: Mon, August 9, 2010 11:32:15 AM
Subject: [DynoMotion] Single point threading on the lathe
Thank you!.
Marty
Group: DynoMotion Message: 550 From: Tom Kerekes Date: 8/10/2010
Hi Marty,
Not yet.  I recently discovered that Mach3 implements G76 as a macro called M1076.m1s that in turn uses G32.  So it seems we just need to implement G32.
Yes to use our controller you must be able to modify a C program.   You don't need to be a C programming expert, but you should be able to read the code and have a vague idea of what it going on to make minor changes.
For example, the program link below is a C program that does the threading motion.  You would likely need to change the "Zend" to move other than 50mm or the "Rate" to be other than 5mm pitch
double Zstart = 0;
double Zend = 50.0*ZRES;
double Rate = 5.0*ZRES;   // counts/rev
Group: DynoMotion Message: 551 From: Ross Ferguson Date: 8/10/2010
In that C program, that you mention, is there a lefthand and righthand threading option?
And to achieve that do we just change the Zend to a positive or negative?
Ross
On 11/08/2010 4:59 AM, Tom Kerekes wrote:
Hi Marty,
double Zstart = 0;
Group: DynoMotion Message: 553 From: Tom Kerekes Date: 8/10/2010
Hi Ross,
That could have been written better.  I think you need to change the Zend, the rate, one "if" statement.
such as:
double Zstart = 0;
double Zend = -50.0*ZRES;
double Rate = -5.0*ZRES;   // counts/rev
 if (y > 0.0) y=0.0;
Group: DynoMotion Message: 561 From: Ross Ferguson Date: 8/10/2010
Thanks Tom,
I can almost wrap my head around the first part, and make some sense of it.
But could you explain the "if" section please?
Ross
On 11/08/2010 8:29 a.m., Tom Kerekes wrote:
> Hi Ross,
> such as:
> double Zstart = 0;
> if (y > 0.0) y=0.0;
> *From:* Ross Ferguson <ferman@...>
> *To:* DynoMotion@yahoogroups.com
> *Sent:* Tue, August 10, 2010 12:00:51 PM
> *Subject:* Re: [DynoMotion] Single point threading on the lathe
> Hi Tom,
> threading option?
> Ross
>> Hi Marty,
>> implement G32.
>> minor changes.
>> double Zstart = 0;
>> http://www.dynomoti on.com/Software/ Thread/MoveZDist
>> PerRevCaptureVer 2.c
>> <http://www.dynomotion.com/Software/Thread/MoveZDistPerRevCaptureVer2.c>
>> Regards
>> TK
>> *From:* Marty Escarcega <escarcega@cox. net>
>> *To:* DynoMotion@yahoogro ups.com <http://ups.com/>
>> *Sent:* Mon, August 9, 2010 7:36:49 PM
>> *Subject:* RE: [DynoMotion] Single point threading on the lathe
>> (I am not)
>> Marty
>> *From:* DynoMotion@yahoogro ups.com <http://ups.com/>
>> [mailto:DynoMotion@ yahoogroups. com] *On Behalf Of *Tom Kerekes
>> *Sent:* Monday, August 09, 2010 12:38 PM
>> Hi Marty,
>> vertical axis is z encoder counts (400cnts/mm) , green is the z axis,
>> http://dynomotion. com/Software/ Thread/thread. png
>> <http://dynomotion.com/Software/Thread/thread.png>
>> TK
>> /Hi Tom,//
>> /Yesterday's exercise was very pleasing./
>> /The results are excellent and I have posted a short video a thread
>> that I cut after our initial tests./
>> /I altered the figures, as you suggested, and the result is a 1.5mm
>> pitch thread on the nylon rod./
>> /I also did a 1.75mm pitch./
>> /Both are excellent - lead-in is spot on./
>> /The threading video is the last one./
>> //http://www.kumeu. co.nz/hankooklat he//
>> <http://www.kumeu.co.nz/hankooklathe/>
>> /I will get to posting on the forum :)/
>> *Sent:* Mon, August 9, 2010 11:32:15 AM
>> *Subject:* [DynoMotion] Single point threading on the lathe
>> Thank you!.
>> Marty
> Ferguson Windmills Company
> 835 Old North Road,
> R.D.2, Waimauku,
> New Zealand. 0882
> Ph 64 9 411 8332 Mobile 027 282 7689
> Fax 64 9 412 8655
> E-mail -ferman@windmills. co.nz
> http://www.windmills.co.nz
Ferguson Windmills Company,
www.windmills.co.nz
Ph. 64 9 412 8655
027 282 7689
Group: DynoMotion Message: 562 From: Tom Kerekes Date: 8/10/2010
Ross,
look for the line like this
if (y < 0.0) y=0.0;
change it to
if (y > 0.0) y=0.0;
Group: DynoMotion Message: 573 From: Marty Escarcega Date: 8/11/2010
Tom, to modify the C program do you need a compiler? Excuse my ignorance, I’m not familiar with it. I can edit config files with a text editor….just trying to understand what I’m getting into.
I don’t mind running your software to control my lathe, but I don’t want to have to edit files when I want to change the pitch of the threads?
Marty
Sent: Tuesday, August 10, 2010 9:59 AM
Hi Marty,
double Zstart = 0;
Sent: Mon, August 9, 2010 7:36:49 PM
Subject: RE: [DynoMotion] Single point threading on the lathe
Marty
From: DynoMotion@yahoogro ups.com [mailto:DynoMotion@ yahoogroups. com] On Behalf Of Tom Kerekes
To: DynoMotion@yahoogro ups.com
Hi Marty,
Here is a plot of captured data showing how the Lathe Carriage accelerates and synchronizes with the desired spindle position.  This data was captured with a spindle speed of ~360rpm and cutting a 5mm pitch thread.  The plot's horizontal axis is time (seconds), the vertical axis is z encoder counts (400cnts/mm) , green is the z axis, purple is the desired z position based on spindle position.
Thank you!.
Marty
Group: DynoMotion Message: 574 From: Tom Kerekes Date: 8/11/2010
Hi Marty,
The compiler and editor comes built-in.  See:
But yes you should wait until we get it fully integrated to Mach3.
